enable mld snooping with-proxy
Description
Enables the MLD snooping proxy.
Syntax Description
Default
Enabled.
Usage Guidelines
Enabling the proxy allows the switch to suppress the duplicate join requests on a group to forward to the connected Layer 3 switch. The proxy also suppresses unnecessary MLD leave messages so that they are forwarded only when the last member leaves the group.
This command can be used for troubleshooting purpose. It should be enabled for normal network operation. The command does not alter the snooping setting.
The following command enables the MLD snooping proxy:
Platform Availability
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
